Any idea what would cure this??
When you push the window button to go up and down, you can press it for a couple of seconds, and it automatically goes down to the bottom or up to the top.
Thing is only the passenger, and rear drivers side does this. What's wrong with the drivers side window, and passenger side rear??
Also the passenger side window seems like the safety is permenetally on, it goes up to the top, then drops a bit.
Would these problems be related, and how do I cure it??
I think you can program them to open or close fully by putting them down, holding the button to put them up and when the window is closed, keep the button pressed for 5 seconds. they should then work like the other ones.
