1 - 1 of 1 Posts
The ecu warning lamp will illuminate when the ignition is switched on, but as soon as the engine is started the warning lamp will go out. If the warning lamp stays on or comes on while the engine is running, then the ecu has detected a fault. If the ecu detects a serious fault then the ecu will then switch to an emergency programme which will allow the vehicle to be driven to a garage, so that the fault can be cured.
To activate the fault codes connect a wire to A and B of the diagnostic plug (10 pin version), then the fault codes will be displayed from the fault code light as flashes, eg. fault code 12 displays as one flash, pause, then two flashes.
To erase the fault code, turn the ignition on/off for 25 times, if this is unsuccessful then disconnect the battery earth lead for at least one minute. The disadvantage for removing the earth lead is that it will erase the memory from other electronic units, eg. security coded radio.
Vauxhall Fault Codes - GM Multec SPi
Fault Code
Associated Component/Cause Of Fault
12
Diagnosis Initiated
13
Lambda Sensor (Open Circuit)
14
Coolant Temperature Sensor (Voltage Low)
15
Coolant Temperature Sensor (Voltage High)
16
Knock Signal Circuit
18
Knock Control System
19
Incorrect Rpm Signal
21
Throttle Position Sensor (Voltage High)
22
Throttle Position Sensor (Voltage Low)
24
Speed Sensor (No Signal)
25
Injector Valve (Voltage Low)
28
Fuel Pump Relay (Contact Problem)
29
Fuel Pump Relay (Voltage Low)
32
Fuel Pump Relay (Voltage High)
33
Map Sensor (Voltage High)
34
Map Sensor (Voltage Low)
35
Stepper Motor (No Idle Speed Control)
41
EST Line Coil Cylinder 2 & 3 (Voltage High)
42
EST Line Coil Cylinder 1 & 4 (Voltage High)
43
Linear EGR System
44
Lambda Sensor (Mixture Too Weak)
45
Lambda Sensor (Mixture Too Rich)
46
EST Lines (Voltage High)
47
Linear EGR Position
49
Battery Voltage High
51
Electronic Control Unit (Memory Failure)
54
Idle CO Potentiometer
55
63
EST Line Coil Cylinder 2 & 3 (Voltage Low)
64
EST Line Coil Cylinder 1 & 4 (Voltage Low)
69
Air Temperature Sensor (Voltage Low)
71
Air Temperature Sensor (Voltage High)
75
Torque Control (Voltage Low)
76
Torque Control (Continuous)
81
Injector Valve (Voltage High)
93
Quad Driver Module
Vauxhall Fault Codes - GM Multec MPi
Fault Code
12
Diagnosis Initiated
13
14
15
16
17
Fuel Injector Circuit(s)
18
Knock Filter Module
19
Incorrect RPM Signal
21
22
24
28
29
32
33
MAP Sensor (Voltage High)
34
MAP Sensor (Voltage Low)
35
41
42
43
Linear EGR System
44
45
46
47
Linear EGR Position
49
51
52
Secondary Air Pump Relay (Voltage Low)
53
Secondary Air Pump Relay (Voltage High)
55
56
Air Control Solenoid (Voltage Low)
57
Air Control Solenoid (Voltage High)
61
Fuel Tank Vent Valve (Voltage Low)
62
Fuel Tank Vent Valve (Voltage High)
63
64
66
Throttle Position Sensor (Hose Broken)
67
Hot Wire Meter (Out Of Range)
68
Hot Wire Meter (Incorrect Frequency)
69
71
72
EST Lines (Open Circuit)
75
76
81
83
Immobiliser (No or Wrong Code)
84
Immobiliser (No Signal)
85
Immobiliser (Wring Signal)
87
Air Conditioning Cutoff Relay (Voltage Low)
88
Air Conditioning Cutoff Relay (Voltage High)
92
Camshaft Sensor (Hall Sensor Circuit)
93
Quad Driver Module
Vauxhall Fault Codes - Bosch And Simtec MPi
Fault Code
12
Diagnosis Initiated
13
14
15
16
Knock Sensor 1 (No Voltage Change)
17
Knock Sensor 2 (No Voltage Change)
18
Knock Control Unit (No Signal)
19
Crankshaft Sensor (Incorrect Signal)
21
22
23
Knock Control Module
24
Vehicle Speed Sensor (No Signal)
25
Injector Valve 1 (Voltage High)
26
Injector Valve 2 (Voltage High)
27
Injector Valve 3 (Voltage High)
28
Injector Valve 4 (Voltage High)
29
Injector Valve 5 (Voltage High)
31
Crankshaft Sensor (No Signal)
32
Injector Valve 6 (Voltage High)
33
EGR Valve (Voltage Low)
34
EGR Valve (Voltage High)
35
Idle Speed Control Valve
37
Fault Code Light (Voltage Low)
38
Lambda Sensor (Voltage Low)
39
Lambda Sensor (Voltage High)
41
Vehicle Speed Sensor (Voltage Low)
42
Vehicle Speed Sensor (Voltage High)
44
Lambda Sensor (Weak Mixture)
45
Lambda Sensor (Rich Mixture)
46
47
48
Battery Voltage Low
49
51
Electronic Control Unit (Hardware Failure)
52
Fault Code Light (Voltage High)
53
54
55
56
Idle Air Control (Voltage High)
57
Idle Air Control (Voltage Low)
59
Inlet Manifold Valve 1 (Voltage High)
61
62
63
65
Idle Co Potentiometer (Voltage Low)
66
Idle Co Potentiometer (Voltage High)
67
Throttle Valve Switch
68
Idle Speed Switch (Not Opening)
69
71
72
Throttle Valve Switch (Not Opening)
73
Air Flow Sensor (Voltage Low)
74
Air Flow Sensor (Voltage High)
75
Auto Transmission Torque Control (Voltage Low)
76
Auto Transmission Torque Control (Ignition Retard Long)
79
Traction Control (Incorrect Ignition/Injection Cut-Off)
81
Injector Valve 1 (Voltage Low)
82
Injector Valve 2 (Voltage Low)
83
Injector Valve 3 (Voltage Low)
84
Injector Valve 4 (Voltage Low)
85
Injector Valve 5 (Voltage Low)
86
Injector Valve 6 (Voltage Low)
87
88
89
Lambda Sensor Heater (Voltage Low)
91
Lambda Sensor Heater (Voltage High)
92
Camshaft Sensor (Incorrect Signal)
93
Hall Effect Sender (Voltage Low)
94
Hall Effect Sender (Voltage High)
97
Traction Control (Incorrect Signal)
98
113
Boost Control (Out Of Range)
114
Boost Pressure Idle (Above Upper Limit)
115
Boost Pressure Full (Below Upper Limit)
116
Boost Pressure (Above Upper Limit)
117
Waste Gate Valve (Voltage Low)
118
Waste Gate Valve (Voltage High)
121
Lambda Sensor 2 (Weak Mixture)
122
Lambda Sensor 2 (Rich Mixture)
123
Inlet Manifold Valve 1 (Blocked)
124
Inlet Manifold Valve 2 (Blocked)
132
EGR Valve (Incorrect Signal)
133
EGR Valve 2 (Voltage High)
134
EGR Valve 2 (Voltage Low)
135
Fault Code Light
136
137
141
Secondary Air Pump (Not Enough Air)
142
Secondary Air Pump (Air Without Pump)
143
Immobiliser Function In Ecu (No Or Incorrect Signal)
144
No Immobiliser Signal Received
145
Incorrect Immobiliser Signal Received
(Donated by Tom Gowlett)
1 - 1 of 1 Posts
