lmao lmao 6psi? thats below a standard LET for a start! then it can handle 28psi :dog: lmao Any lets blow the sheeeeeeeeet outta it gen? expect its got a bleed valve Don't think he has any idea about it really!!! :dog:
someone ring him it's gotta be done and record it, don't have to do anything just ask about the boost, the 5th injector, swirl pot lmao and the cammed gearbox. lmao lmao lmao af1 do it, where's he at
i emailed him yesterday totally slating him basically. i got an email back
I didnt say is, I said was!!!! Only listed what i was told to, get a life, and stop harrasing people for no good reason. Like my mum used to say If you havent got anything nice to say, dont say anything.
Its desperate when you have to quote your mum when someone is slating you! I hope he joins this thread, I want to know what duration and lift this cam in his gearbox is running! lmao
There is no 5th injector lmao - courtenay only use this for NON turbo applications where they add a turbo - lower the compression and add another injector so enough fuel can be supplied coz the OEM injectors with the ecu were never designed to flow much fuel.
This donkey has no idea !! lmao
6psi boost on an let ?? obviously no-one has told him it's running under power lmao - As for being the quickest Astra in the UK tehe - I bet a TB'd Astra would have that !!
He's probably luckiy it is only running 6psi - any more and you'd be picking up bits of F16 half a mile away lmao
Related Threads
Vauxhall Owners Forum
4.7M posts
72.6K members
Since 2000
