Downsides to a lightened flywheel.
1 reading
11K views 63 replies 19 participants last post by  Gordo
#1 ·
I'm fairly sure I have covered them all in my head, but I'm curious to see others opinions on the matter.
I'd appreciate if comments could be backup up with real knowledge and experience rather than speculation.
Fire away -
#11 ·
Yeah on my mini trackday car I pretty much had no choice but to heal and toe it cause of that, especially as it was a high comp engine, its amazing quite how quickly the revs come down compared to on a normal weight one.
#12 ·
I asked this question recently
I drove a Calibra V6 this week with a Courtenay 5.7kgs flywheel in it. Revved quicker and was still easy to drive. Only difference was it seemed like you had to press the throttle more often than you do on mine if that make sense, probably because the revs drop quicker. Made a big improvement to accelleration.
However, it somehow didn't feel like a V6 anymore. Was quick like a V6, but felt more like a tuned C20XE than a smooth V6.
I know it's only my opinion, but thought I'd mention it anyway :) I would think on a 2 litre it will just feel quicker with no drawbacks
#14 ·
It depends on how light you go, there is an optimum weight for any application and in the case of the standard v6 its FAR too heavy
Xe one if you lighten it is a bit is good, but there definately start being downsides when you get mega light.
#23 ·
There is only one reason why we disagree, and thats becuase the things that were being said were incorrect..
You were trying to tell me that a lighter flywheel will reduce engine braking, and thats simply not true, it will increase.
then after you realised i was right you came full circle and said it would effect drivability..wtf..
Maybe when you change your flywheel you can buy a heavier one and increase drivability and engine braking!
#34 ·
Forget linking it to threads you just found on google........... its simple high school physics.... up hill down hill on a corner in a field...
You said it yourself the flywheel stores energy, if a lighter flywheel stores less energy it will be slowed down easier on over run.
#41 ·
yeah but your slowing down,
Lets look at it a different way, your in a car with a heavy flywheel at 40mph and you lift off the heavy flywheel has more stored energy in it rotation keeping you rolling for say 300 yards.
if you then put a flywheel half the weight on it you are reducing the stored rotational energy and therefore the car has less energy to keep it moving and wont be able to roll for the same amount of distance.
make sense now?
#49 ·
that might be a downside to a "lightened" flywheel, but not a "lightweight" flywheel!!!!!!!!!
The weight loss talked about in this thread can't be achieved by machining a std cast flywheel, or it will indeed be likely to go bang. However, fitting a lightweight steel flywheel will reduce the chances of the above disaster compared to a std flywheel, as the steel one is much stronger!
#54 ·
Problem is with the cast flywheels when lightened, even if they are lightened correctly and sensibly, cast flywheels will crack with repetative expansion and contraction... so you think its safe untill one day Kbooooom, so unless you check it regularly for stress cracks you never really know if its ok or not.
Even the lightest steel flywheels we make will exceed 20,000rpm and wont crack.
I looked abit closer at that footage, looks like most of the flywheel came out of the bonnet and the clutch came out of the front
you can see it here
#56 ·
There have been quite a few Mini 7 racers who've received nasty leg injuries from exploding flywheels/clutches and I believe there've been at least two fatalities!
A clutch explosion is why 'Big Daddy' Garlitts built the first rear engine dragster - he'd lost half his foot in the accident.
#63 ·
Ive been in a corsa v6 with a lightweight fly and it seem to accelerate alot faster, When i come to a hill at a constant RPM (Keeping my foot still) car the seem to slow down due to the loss of mass on the fly, but when i put my foot down to regain speed it still seemed to pull harder
so in my eyes its better to have a lightweight fly as the engine does not need to use as mush power to move the rotational mass of the engine (Aswell as the cars mass)
