1 - 10 of 10 Posts
bought wrongly as i was told the rear doors on the zaf were a nighmare to do... which was the wrong info, i got these which are now surplus. rated at 90w with tweeter and direct fit for all the above mentioned cars. inc connectors for standard wiring and fitting screws.
£60 inc delivery. pm if interested, or reply here.
gav.
Discussion Starter · #4 · (Edited)
i think they are around 50wrms (or should be as its around half the power) these have smaller driver magnets so no need for cutting doors at all and are fitted with the spacer ring already. pop the old ones out, fit the new ones.
Gav,
u need to put the "url" = in your siggy to hyperlink it...
Not sure if these would be good for me... I'm having 2 x 12 Audio Bahns, with a kick-azz amp, Pioneer 6x9's on back ...used for mid & treble only (As enough bass thro subs when they rumble) and require a decent powerful set of treble & mid speakers for the fronts to keep up with everything else.
Are they up to the task? Will be amped to a smaller amp.
1 - 10 of 10 Posts
