1 - 10 of 10 Posts
taking block out with a crane but want to fit it back with the head on.
whats the level of difficulty with it on as apposed to off ?
chip said:
easier with it on as it means you can do things like the timing belt while its out.
just the getting to silly things like the matrix heater hoses and gearbox to engine bolts eh
leesturbo said:
but to make room for going in doesn't all the cambelt and rollers etc need to be off (gearbox in car)
Morning Lee, when i did mine i had too but like you said last night if you undo the gearbox bolts you might get it in, here are a couple of pics of mine and it was tight :
put it in complete without the inlet and aux drive pulley, takes about 10 mins, then as the inlet isnt on do all the bits down the bacl of the engine first and fit the inlet last.
Discussion Starter · #10 ·
liking this idea! i ideally want to put the head on out the car then i can test i have a good sealed engine before fitting!
1 - 10 of 10 Posts
