1 - 20 of 49 Posts
yeah, its just dissapointing because it sounds like i've got a hole in the exhaust (well, i suppose in a way i have)
Great for blasting past people with open car windows as well lmao
had one for years mate
rik, if you space the actuator away from the vent it closes harder and stops the leak (did on mine anyway)
chip said:
not easy to remove to clean out either :(
you just apply air pressue to open the vent and then clean it out
oh ps i sent one to trev about a year ago and he should be making his own soon
Moderator
To fit that on a std kkk, your gonna make a custom elbow including the lamda, to then incorporate the screemer??
Moderator
T.F.S.© said:
it goes on the exhaust, not the turbo
it just welds in, 30 min job
Hmmmmm, just trying to work that out in my head.
have a look on that link (and the link to the VTS website) it explains it fully with vids and pics
basicially you remove the cat, put straight pipe inbetween (regular decat then!) and then put a t piece in eith the vent on it......when boost hits 17-20psi the vent opens and grannys get scared!!
its an actuator valve - same as what you'd use on a turbo for boost control...........When u reach whatever boost it opens the actuator (via boost pressure) which pulls the rod back, allowing the flap to open and let all the exhast gases escape ;)
It basically allows u to keep the nice and quiet exhaust system whilst "off boost" and then when your on full chat and wanting the exhaust to flow really well...the valve will open ;)
Good idea - only downside is it's gonna be SO loud lmao
Moderator
And it might set light to the bottom of your car.
What about back pressure for the turbo, or is enough created from the downpipe.
Surely spending money on that you should look at having a custom elbow made up with a lamda in it, that'll help flow even better, although i like the idea of it sounding like a jet!
wonder if thered be any way to make that work N/A, like ollys old nova, std quied 3 box exhaust and then that out of a single large box or something lol.
prolly need to use exhaust pressure to open it or something.
Discussion Starter · #18 ·
Just replace the actuaator with a solenoid fired at 99% throttle or something along those lines.
Moderator
DaveB has/had the same system for his TB's, made it a side exit.
its opened using boost so would not stricktly work on a n/a car
but you could have a little cylinder of air that you could use solinoids to send pressure to it and work so yea you could fit on to a n/a car
1 - 20 of 49 Posts
