1 - 18 of 18 Posts
daylight switch problem (Daytime Running Lights)
Here is my problem:
When I start the car the low headlight is not turning on anymore. The position lights are working ok and also when I turn the light switch the head light will go on, both low and high beam.
I can hear some relay cklicking just after start but still the low beam is off...
Does anyone have a clue? Where is that daylight (Daytime Running Lights) relay located?
Thanks!
:beer:
Discussion Starter · #2 ·
anybody?
fuse is OK, if removed the sidelights are going off also...
from the electrical schematic I've seen that the DRL relay contains actualy 2 relays, is it possible that just 1 of them is out-of-business? and again where is this DRL relay located? i think is not in the main fuse box...
Discussion Starter · #8 ·
hello again...
yep, it is kind of difficult to see under the fuse box :D i couldn't see anything and i tried many positions lmao
I will try again and also recheck the fuses but all looked OK...
I don't remember the oil light on or off, but lets see...
:beer:
Discussion Starter · #10 ·
Andy K said:
Yes it's above the fusebox. probably best SEEN if the headlight switch panel is removed.
I've got the idea :D
fuse 18 OK oil light also turning on at start... i will remove the switch and have a look...
Discussion Starter · #11 ·
morning all!
I've found the DRL relay and yes, it is behind, above the main fuse panel. It was realy difficult to reach it, my hands are full of scratches :eek:
but the bad thing is I could not remove it and i tried hard, i could not pull out the connector eather...does somebody know a trick?
also a big mistake by me was that I havn't had anything for testing the electric stuff... no results yet just that I could feel the relay clicking...
They are very difficult / impossible to remove.
The only chance you may have is to remove the 4 screws around the fusebox and pull the cage out the back with the DLR bolted to.
So what's not working then ?
Are the left and right side lights/tail on ?
Are the headlights on ?
Discussion Starter · #13 ·
sidelights are on so one relay from the DRL is working.
headlight si off even if I coud hear/feel the timed click of the other relay after the start or when turning the light switch... I've got a tester now and I will check if there is volts comming out of the DRL for the hedlight...
Discussion Starter · #14 ·
hmm... I have removed the fusebox, there were 3 screws, that's how I reached somehow the DRL unit... but it is bolted to something which did not look removable... strong metal bar...
might be because of the left hand drive version? :confused:
Discussion Starter · #15 ·
yesss. I have fixed the thing. The DRL board slided out quite easely somehow, I dont know how... I was just trying to remove it and than sudenly it came out from its plastic box. It was still a problem to remove the connector after that.
the welding of the headlight relay has melted and there was no connection anymore... but easy to fix after it was removed.
:beer:
The DRL circuit looks quite weak for those amps that are running thru it...
Discussion Starter · #17 ·
Andy K said:
glad it's fixed.
sorry I hadn't noticed you have been replying.
No problem, :beer:s for the help. I could have looked for ages after that damn DRL :D
and sorry for my hungarian, romanian, finnish english lmao
Hi, I'm from Spain. My left daylight bulb is not working and I get a dashboard error message: check left daylight bulb.
It seems that there's not power coming to this light when I turn the contact on. If I do it manually, I see the bulb on on daylight mode.
Do you think it could be the same problem?. Do you have any photo of the part you repaired?.
Thanks in advance
1 - 18 of 18 Posts
