1 - 15 of 15 Posts
got a corsa-c and theres a knocking/creeking noise from the back wheel area! its not a constant noise. comes and goes. how a look under the car and took the standard wheels of and nothing seems to be rubbing, knocking or loose! what could this be? maybe its just something/somepart i need to lube up? :confused:
Discussion Starter · #9 ·
yeah its hard to figure out whats the noise coming from as i dont really have the time to take it to the garage for them to have a look but looks like i may have to find some time!:( !
THis might be a long shot but i had a knocking on my corsa c stripped all the interior out as it sounded like it was from the rear but it turned out to be the door lock and strikers on the front doors. Adjusted and greased and all was hunky dory!:beer:
ive got a knockingn noise from the back of my car ( vectra ) and have been told its a bush gone on the back, maybe the same is with ure corsa?? or the heat sheild from the exhaust as mine was banging before i removed it.
Veccy and corsa use different setups. Spoke to my mate at a dealers today and they have known the anti roll bar creak which stumped them for ages as it runs in the rear beam.:eek:
Maybe the exhaust system itself? if u have a heatshield or anything close (doesnt need to be touching when u look at it) to exhaust, it may just touch something and create either a knock or creek. Get someone to bounce the car up and down while u look and listen underneath the car, the exhaust and other parts will sit differently when the ride height changes
Just a thought, but turned out it was the exhaust causing squeeking and creeking on my dames Corsa B, newer model could be similar?
Discussion Starter · #15 ·
so is there a way to lube this part up?:confused:
1 - 15 of 15 Posts
