1 - 8 of 8 Posts
im fitting my megasquirt which now has the option to run on a toothed crank wheel to fire a coil pack.
does anyone know if the xe and the xev cranks are the same?, and also what are the specifics of the wheel (the XEV one) i.e. the no. of teeth, the no. missing and also what the are lined up to i.e. missing tooth = 0degrees or 10 btdc?
cheers yet again.
megasquirtnSpark Extra reads the crank wheel and fires through a ford edis setup.
i dont know if the ecotec uses 60-2. i know that the XE does. and i know that the trailing edge of the second missing tooth is the refernce point and is 120 deg BTDC on cyl 1.
1 - 8 of 8 Posts
