1 - 7 of 7 Posts
had the let in for about 11mths now and the only problem i had was eratic boost. my boss put whats called a bren device on it (an mbc), pulled 6psi constant so we wound it up a little bit to 11psi. run superb. then turbo bearing seized :( . but considering the turbo had 90000 miles on it , it was due a rebuild. i got turbo dynamics ( recommended by apex) to rebuild it to a speck i wanted.my boss is knows more about turbos than me so got him to speak to them and tell them what im after.
the pics are before we had to put the actuator on.
Get p2 and crank the boost up a bit. How much did you get your ass reemed for the rebuild?
all i need is a fuel pressure reg and i can run phase 2. it cost 450 all in.
i think i got a discount for saying apex had recommended them. every bit they have used is uprated. they have said it will run constant 25psi.
It may well run 25psi,but nay flow much and run some mega high inlet temps. You need a hell of an intercooler/chargecooler to cope. Lucky p2 doesnt require such high boost.
1 - 7 of 7 Posts
