1 - 1 of 1 Posts
Hi everyone I’m new to the forum wondering if someone can help me with this corsa d engine problems
Things done so far changed Ecu due to water damage,new Ecu is perfect no water inside at all engine starts and runs then after a 5 minutes cuts out it restarts first turn then same symptoms iv changed fuel pump,injectors,rail sensor,egr is clean and working,crank sensor and cam sensor changed throttle flap maf is working
Op com say fuel pressure is perfect no fault codes on op com
Iv have a video of the symptoms on YouTube not sure if I can upload on here any help
Would be highly appreciated
Video link
1 - 1 of 1 Posts
