301 - 320 of 339 Posts
Wow, you have almost enough parts to build up a second gearbox in an alternate spec' - like fast and tight track - and you can use it as an emergency spare even if the ratios aren't as might be desired.
Discussion Starter · #303 ·
I wish, There's about two thirds of the available ratios there but its a long way from enough parts to build a spare box or even a spare cluster. Plus explaining to my better half why I need another gearbox to go with the one in the car and all the spare parts is a conversation I don't think I want to have...
Air guides straight from the tool
Start trimming
Test fit
Bend up some mesh to keep rocks, wildlife, small children out.
Hold it all in place with wire and lollipop sticks whilst the glue sets
Discussion Starter · #306 ·
A small update. I needed to do something with the bulkhead closure plate where the gear selector used to go through so.
I removed it from the car and weighed it of course...
Trimmed it back to leave the flange and screwed it to a board
Filled and pattern coated the plate
Flatted and polished
Mould pulled and polished
Layed up and infused
Pulled from the mould
Trimmed and weighed, a 130g saving.
Steel hold down nuts
Replaced with aluminium, another 50g saved
and the plate fitted
Also I have been doing a little mapping but have had to order bigger injectors as I've run out of duty at 1 bar boost at 7200 rpm.
Agreed, he's one of those lucky people who enjoys the building at least as much as the driving - the better end of the deal, IMO, as instead of a few hours he has hundreds, even thousands of hours of enjoyment out of the car a year!
Discussion Starter · #314 ·
Wow , what a build , just read through all 16 pages and it’s very very impressive , the skill , detail and execution , unreal ..... well done mate
withought worths
Thanks fellas
I really do enjoy the building, probably because I'm better at the building than the driving.
Ask away..
Do you have any more pictures of the fitting process on your Areocatch's before you changed your slam panel?
And in reference to the use of the z18xer sump, are you able to help me understand a little better what else is involved in relation the the dipstick, and the oil pickup pipe etc?
Absolutely love the build thread, its nice to see someone else whos not afraid to put some actual time and money into "just a corsa" :cool:
Discussion Starter · #317 ·
Unfortunately I'm pretty bad at taking photos as I go along so the ones that I post are the only ones I have. The way I initially fitted the aero catches was to fit the pins to the slam panel then adjust the length so they just touched the underside of the bonnet outer skin when it was closed, I then apply a small drop of paint to the top of the pins, close the bonnet and that leaves a paint mark which you can use as a reference for the catches themselves. Because the pins and bonnet arent neccesarily at right angles to each other the refrence point wont be exactly correct but its close enough as a starting point.
To use the z18xer sump you must use the z18xer dipstick and tube which plugs straight into the sump and then block the hole in the engine block where the standard one fitted.
When you take the sump of the z18xe, it looks similar to this...
with the oil pick up snaking across from the pump to the deep part of the sump. Because the 18XER sump has the deep portion at the other end this wouldnt fit and normally you'd have to modify it, however, the XER sump has the pick up cast integral to it. like this...
oil flows up the casting with the green arrow and out of the rectanular(ish) hole. That hole is quite large and very close to the oil pump casing, so to make the adaptation easier I cut a piece of aluminium plate to fit the hole and cut a smaller hole in the center.
Then made the alloy block...
that bolts in place of the original pipe and lines up with the integral pick up of the sump.
hope that helps..
Discussion Starter · #318 ·
Not much of an update as I haven't been able to do any proper work on the car for three months, mostly because of continuously poor weather, but I did take it out for a little mapping session the other day and tested the launch control on a slightly damp road, all went well until the launch control switched off and then it just spun the wheels.
Discussion Starter · #319 ·
In an attempt to get a wider range of boost control I've decided to ditch the regular BCS and actuator setup for a garrett electro-mechanical actuator usually found on VNT diesel turbos. One of the ideas been that I can force the waste gate open when launching and stop the engine effectively going into anti lag and building boost.
First task was to source an actuator that's PWM controlled and not can bus, turns out a 6nw008412 will do.
So remove the standard parts.
Then make a bracket the mounts the new actuator on the stock mount.
Fit a 2 pin plug on the actuator and earth it locally to the bracket and a ball joint on the actuator arm, this and the above bracket means I can easily swap straight back to 'normal' if I have to
Actuator mounted and aligned with wastegate arm
I'm slowly homing in on the settings, currently it will launch around 3 or 4 psi, building to about 8 psi, then 12 PSI in 2nd gear and 15 in 3rd upwards..
Also, My custom short(er) stroke crankshaft arrived today, its only taken 72 weeks!
Discussion Starter · #320 ·
No big updates.. after fitting the servo wastegate control I did a little more tuning of the boost by gear and launch control..
For a while now I'd been thinking about moving the engine oil radiator and ducting it and the gearbox oil rad together. The engine oil cooler wasnt causing any issue in front of the water rad and intercooler I was just after better packaging..
So armed with some cheap aluminium I set about it.
The gearbox rad sits directly behind. When I have some time I'll pull the aluminium panels off and replicate them in carbon.
Also its now getting to that time of the year where its too cold to make moulds and the resins that I have need using up because there getting close to expiry... so I was moving Cecil and as I parked him up I thought 'how much does the handbrake weigh?'
May as well weigh the floor closure whilst i'm here..
A little grinding later and we had the constituent parts, the base could be lightened but it would require a pattern making to take the teeth and a new spindle which I cant make at the moment because I cant get to the lathe, bloody lockdown.
I can probably do something with the lever halves..
But the way the're formed doesnt make them easy to use so a little modification was required to the 'handle' end
and a coat of primer to stop the mould sticking to the filler
All prepped up for moulding
moulds made
Floor plate first
not a bad saving
Half a lever curing
Again a pretty significant saving.
Final assembly
so total 668G vs 1285G almost half the weight..So not worth the effort!
