I used to drive a Chevrolet Utility (Corsa D chassis) which has the "tap indicator once and flash 3 times" function which makes motorway driving better.
Now I have a Corsa C Utility (it is the brazilian made version in South Africa) which doesnt have this function. Does anyone know if it is possible to retrofit it? The indicator stalks on the Corsa C and D (here anyway) are identical.
The flashing is controlled by the BCM as the stalks on the Corsa c are CAN, not sure if this can be programmed in.
