1 - 17 of 17 Posts
Which pin is for the backlight of the mfd clock? I got the clock working just you turn on the loghts the mfd does not light up
Sent from my iPhone using Tapatalk
Is it not a twist and turn bulb holder for the lights? Or is that just a corsa b?
Sent from my laptop sat on the sh1thouse
No its corsa c ueah there twist bulbs they are in its when you press the button they light up bit when you turn the lights on the mfd clock does not light up
Its a corsavan there was no wire loom i could not find it so have to wire the mfd my self
er, this might sound a bit daft, but is the dimmer for the dash lights turned down?
Na its full up
U know the wiring diagram for the connector?
Discussion Starter · #7 ·
The display gets the dimmed illumination feed from the BCM on pin 4 gray black wire
Ok you know what the other pins are for aswell?
When you start the car is the display supposed to on?
I know what pin 1,3 and 6 are
is it a multi functon display or a tripple info display
TID
1 -12v ignition
2 -radio
3 -12v constant
4 -illumination from bcm
5 -outside temp
6 -earth
7 -outside temp
8 -diag link
9 -speed signal
10 -radio
11 -radio
12 -radio
Discussion Starter · #9 ·
Its a multi function display the one in a corsa c 2002 reg displays time,temp,date and radio station is the triple display in old corsas?
Discussion Starter · #11 ·
Yh its 12 pin
I wired the pin 1 3 and 6 and the clock only lights up if i press the button on it and then turn off
When the car is on it does not tun on automatically
Discussion Starter · #14 ·
Got it working all wired up temp sensor going to be fitted
Mfd fitted in a corsavan
Can you assist with how you got it working please? I have the same, only goes on when I press the button, then it goes off
Hi I need assistance mine doing the same. Does not stay on when ignition is turned on. But when you press the buttons go on for a while then goes off. I have corsa c
1 - 17 of 17 Posts
