Hey i could use some pics of the back of a vdo cdr 2005 if any 1 has them it would be well handy.
Also any hints on how to wire a JBL BTX250 Active Subwoofer Tube in to the corsa. should i use the vauxhall speakers and a new head unit or a boot build and wire it whats the best option??? Iwant the car unharmed for when i punt it on.
Thanks in advance Roybacer!!!! :confused:
i recently put a sub n amp in my new corsa with out making a mark,
i would suggest a new head unit and just keep the old one, when getting a ISO converter i had to get a BMW one for some reason and also they dont have a ignition wire going to it neither,
For putting through the wire took me a while to find a place to feed the wire but if you look just behind the battery theres a wire going in with a rubber thing if you just pull that out and feed it through along side it. most of the trim simply unclipps just needs a careful pull but look out for the odd screw.
