Another Corsa 1.4 Auto, its selector leaver wont shift even when brake pedal is pressed, found the problem with a small twin microswitch that has 3 wires near the selector leaver, this switch is also responsible for ignition key staying locked in and unable to be removed from the barrel.
So I have been looking at this micro switch, appears to be bad switch, someone suggested re-soldering so i did that, and all seems to work now, the shifter leaver moves into drive etc, when brake pedal is depressed, but for some reason or another the Engine will not crank at all now.
On the dash speedo display, 3 yellow bars display which the owner did not seen before. Also the display will no longer show in which position is the selector leaver, so I my guess is one of the many other wires may have got pulled as the center console was being removed by the owner, not by me, I would have taken more care of not tugging or pulling on the wires.
Any other thoughts on this please let me know what else can it be, even the LED indicator lights near the selector leaver do not illuminate to indicate which position the leaver is in.
Owners get these problems and start to look into it and finally when nothing else works for them I am called upon, but all i can do is ask here, as I do not have any experience in fixing Corsa electronics.
Thanks in advance
Thanks in advance
