1 - 12 of 12 Posts
Hi there,
I hoping all you peeps out there could help me out a problem I seem to have.
I have the newest shape Corsa with the CD30 as standard.. and after some investigation found out that i need a ISO converter to attach my Sony Head Unit. Only problem is every place I go into has never seen this type of connection on the back of the radio :eek:
So over the bank holiday I went into the local Vauxhall Part dept.. they were shut.. grrr... So to the internet! I have now found out that the converter is £25 for them! And so is the double dinn fasica.. I have found loads of places that do the double dinn but they are only in black.. where as the corsa interia is Charcoal.. So what to do?
I really dont want to pay out £50 to have my good stereo in my car but i'd like to have my sub, amp and boot changer..
Any help from you guys would be great! :rolleyes:
Kim
P.S. Im also after some colour coded body parts in Star Silver if anyone knows of/has some. :D
What does it look like?
Post a pic if you can.
does it look like this?
cos if it does it's the same as my Cav and it plugs straight into an ISO so no need for the adapter i bought from halfrauds.
To remove it from the back of the radio you have to squeeze 2 clips and pull a little lever type handle.. thanx for the link i'll take a look there.
and by the way theres no ignition wire (yellow wire) i had to link the ignition to battery (yellow to red) for it to work but it doest turn off with the key
Discussion Starter #9
One question tho.. What did you do with the double dinn fasica? Did you get one to match or did you end up going with the black one?
1 - 12 of 12 Posts
