Nova on coilovers rear height problem
hey, got myself some new coilovers to replace the tired ones i had before (also avo coilover but without the ride height adjustment at the rear) and i can't seem to get the back end sitting high enough, i've got speedlines and it scraps like a bastid yet it didn't before. i've got the hight as high as poss and it still doesn't sit as at the same level as before. could it be that the damping is too hard or soft?
let the shocks wear in and as they go softer they will go higher its all about the damper rebound. plus have you got a boost valve and a inlet manifold this really could be the problem. try using optimax fuel that will work deffinetly will work trust me i work in tesco
failing that, try changed ur fog light bulb, this should work.
are you trippin'? lmao
ttt
