hi had my clutch changed on my zafira 1.9 07 plate diesel. When l picked the car up the steering wheel was off centre now the esp light is on constant anyone any ideas
if you dont have a scanner, to check for fault codes, you might wanna check the speed sensors, on both front wheels.
check if the connectors are plugged in properly - might not be clicked in fully, or be a bad connection.
and check the front face of the sensors while your there - theyre magnetic, and can get flakes of crap/rust stuck to them, when the mechanicals get disturbed by repair work.
the off-centre steering wheel - im guessing they dropped the subframe, to do the clutch, which has either knocked the tracking out a couple degree's, or theyve possibly mis-aligned the teeth on the steering rack/column perhaps, or maybe a bit of both.
