folks,
what's the usual on an XE engine? with the clutch pedal up, should the release bearing sit lightly on the clutch release fingers, or should it sit back off the fingers...?
is the vauxhall pedal spring loaded to 'push' the release arm away from the clutch?
I've started to get an annoying rattle unless I gently rest on the clutch pedal (clutch doesn't slip until plenty more pressure on the pedal...)
grb
grb
