What does it output???
Is it a +12v output which you can ground to the car?
Is it a negative switch which you need to hook up to a live feed?
Is it +3v out?
Or what?
Any gen most appreciated.
its a low amp switched negative if you want to switch anything on with it you will have to use a relay. you can also program it as a timed output
Welcome to MIG, BTW.
Cheers, i'm making a circuit to latch it on and off rather than only being on when the button's pressed. Some guy from clifford told me it does this anyway but i've heard from loads of people that it can be a pulse or timed but not latched.
