charge coolers also come with a boost pressure switch so that when boostpressure reaches 0bar it starts the pump up. surely this is bad, why not have it running all the time? as when your cruising on the motorway it wont be pumping water round the system so the charge temp wont be all that low, soon as you floor it, the pump fires up, but if the temperature of the water has risen quite a lot with being on a constant cruise, when you need the more condensed air at like 1bar, it wont be there, it will be too hot in temperature.
so therefore, why do you get this pressure switch thing? im gonna run mine on constantly, unless there is a reason against this
