1 - 10 of 10 Posts
How hard is it to change the waterpump on an XE corsa? whats it like for room?
The engines currently out but I cant undo my bottom pulley while its out the car :doh:
Tried locking the flywheel but still not having it, I thought if I done it once its in the car then at least I can use the box and breaks for some resistance
Anyone got any recomendations?
Ian
Bottom pulley has four allen bolts holding it on correct?
If so, use a 19mm (iirc) socket on the crank bolt and hold it still while you undo the allen headed bolts...
Easy as pie
The fool who owned the engine before me changed the allan bolts for normal headed bolts, dont know how because you cant get a socket over them at all ,
No choice but to take the main E20 bolt out and pull the entire pulley off
Drill the heads off the 6 bolts holding the lower alternator/PAS pulley on. Once the bolt heads and the pulley are off, unscrew the remaining parts of the bolts with a pair of mole grips.
Nearly shifted it before but as I wasnt using an E20 the socket slipped...
Gonna wait now and get myself an E20, not worth risking it anymore as if I round it off im well and truly furbered :eek:
If that fails then i'll crack the ole' black and decker out :nod:
Just remember that you're (ideally) going to have to get a new bolt and apply about the same amount of pressure to re-tighten the bolt again afterwards. It's about 180Ibft and a 50degree angle turn.
Discussion Starter · #7 ·
Im going to replace the bolt and hopefully get the 13mm's that have been used replaced for normal ones aswell, if I cant get them out im getting a new pulley!
I'll post how I get on,
Any idea where I could get an E20 socket on a Sunday?
Ian
You do realise that you can change the water pump without removing the E20/lower cam pulley? I thought you were removing the E20 because you couldn't undo the other 6 bolts. If you plan on replacing the 6 bolts anyway, then I'd just concentrate on removing them and leave the E20 alone.
Discussion Starter · #9 ·
Keiran,
Basically the engine is in my garage ready to go in my corsa but I want to change the pump and belts first,
Im gonna have to go for the drilling now but im bothered that if I drill the heads I might not be able to remove the screws with molegrips afterwards
Once the heads are off, the remaining threaded part should be finger tight. It's the rust seal between the heads and the pulley stopping them from turning :)
1 - 10 of 10 Posts
