does anyone have a guide with pictures or anything on how to do this for the rear?? I just need to change one spring and was wondering do i need to go out and get a spring compressor for it???
any help appreciated ASAP thanks !
Scott G said:
You dont need a spring compressor from what I remember.
Just remove the bolt at the bottom and the arm will swing down and the old spring drop out.
Fitting the new ones is the opposite of removal.
the bolt at the bottom of the shock. you may need to get someone to stand on the beam to get enough space to get the spring out. 15 minutes each side.
