1 - 7 of 7 Posts
any idea how to remove the front bumper from a cavalier mk4? im having real difficulty, ive sprayed a gsi bumper i bought and its lovely and blue and laquered all ready to go on but can i get the old bumper off my car? no! cant even find whats fixing it on, ive unscrewed the bolts from the inner arches to the bumper but its pretty much impossible to get access to any other fixings, has any of you done this before?
thanks very much! as im dying to put this bodykit on!
there are 2 13mm bolts still holding it on look above the fog lights and you should see them.
del
ps i think you mean mk3 cavalier:D
thanks for the reply, its the newest cav b4 the vectra, how do i access the nuts? the bodykit is from a mk3 tho
L
Guest
The drivers side bolt is accessed from in the engine bay, Feel around where the chassis rail is under where the airbox sits, The bolt is around there.
The passenger one is accessed from in the inner wing, If you have a washer bottle that goes through into the inner wing you will need to remove that, then you can see the other bolt that needs to be undone.
1 - 7 of 7 Posts
