1 - 12 of 12 Posts
also got another problem,driving at 30ish..put foot to the floor to speed up quick! car(cav gsi) splutters but if put foot down slowly its ok. tried air flow meter but thats ok. told it might be the cat. anyone had the same problem? feels like wrong fuel mixture or something restricting the engine ect.
whan was the last time it was serviced? new air filter, plugs etc etc. and also replace your fuel filter if it hasnt been done in a while.
are you getting any fault codes coming up?
rodgerq
full service the other week,still did it!!.no warning lights coming up!! and the fuel filter was changed last week. car only does it when bury foot quick but if build speed up quickly it happens.
just put a k&n on it....noticed it after that really. thought it would have gone better with no messing about putting k&n's on..... :confused:
does anyone have a link to the breather mod then.
better try that.
to be honest some of them just dont agree with induction kits all together, whether you do the breather mod or not. its tod o with the hot air entering the filter instead of the cold air that the standard box and snorkel would feed it. you'd be better refitting the standard box and putting in a panel filter. maybe even drill the bottom of it out for some induction noise.
rodgerq
Yeah, try puting the OE back on instead of the K&N......see if it still does it.
Have to say my SRi doesn't give any grief with the K&N.....cold air fed from bottom of the bumper and original feed for air box
Discussion Starter · #9 ·
well pus standard box back on it and cured it about 90% still judders a bit.when k&n was on back box snappen and untill i put another on it stopped stuttering as much...why was this?
Administrator
you may want to reset the ECU by removing the negative off the battery for an hour, then drive it again
an aldo clean the idle control valve
tom
Discussion Starter · #12 ·
tom
how do i clean the idle control valve and where is it?it it easy and the misses would like to know HOW LONG???
1 - 12 of 12 Posts
