1 - 1 of 1 Posts
Hi all,
Can someone confirm which fuse supplys the ECU on a J- reg Gsi 2000
Motor cranks, no FPR coming on,no spark.
Perm +12v is going to FPR, but relay is not switching.
Pump does run when a wire loop is used across the 'to pump' and 12V wire at the relay.
Fuse13 (FI) is not getting 12v with igntion on.
Suspect the ecu is not coming on, and not giving the ground signal to the FPR.
All fuses appear to be ok in fusebox.
Any help with vital ECU pinouts on this model would be helpful.
thanks
1 - 1 of 1 Posts
