1 - 20 of 28 Posts
well guys cavvy failed her MOT today
abs warning light is on
any suggestions what may be the cause of this?????????
and also emissions were a bit high both co and lamda came in at 0.60
so suggestions for dropping this would be nice too
cheers guys
S**t one rob.. A think youre just as well putting the cat on. what else it fail on?
Cant you just turn your headlights down with that headlight adjuster switch inside or does that not count?
lol nah easy sorted bit of fettling they'll be fine
concerned about the abs tho
gonna be a **** to get this running
mmm quick fix would be to take the abs light out the dash, but if he's on the ball/a hitler he may notice it doesnt come on when the car is started, to fix it properly it's probably a duff sensor , not really sure how to test them except changing them until you find the faulty one
new plugs / leads will help emissions if you haven't done that already, also, rag it before the test so it's warmed up
It will most likely be one of the front abs sensor wires - where they twist when the front wheels move the wires inside break.
Borrow/rob some from the local scrappies - but be aware the plastic holders often stick to them and break. However these are only about £1.30 from vaux.
Could also be muck etc on end of them, but in my experiance that's not too likely.
So how do you change an abs sensor? I need to change mine. Also how do you remove one from another car?
Gary
You jack up front of car on side you want to change.
Take off wheel.
Turn steering so you can see abs sensor which is pointing to driveshaft.
Use suitable tool to undo bolt (either posi-drive headed bolt or hex bolt IIRC).
then pull/twist abs sensor out of it's plastic housing.
unclip wires.
refitting is reversal or removal.
I take it you guys down own a Haynes manual too don't you?
the back ones are held on by the bolts that hold the caliper on on a bracket
I think the fronts just tap out...but I really can't remember...
i sont have haynes manual.. Defo think i should buy one though! A will get one when got more money. Just need to know how to get abs sensor off. So you's suggest i should also check wires? I just changed bat from fooked one. Can this set do anything to abs or brain??
WeegieBoob - Sorry for hijacking thread but need to know.. :)
Gary
He's away home now. :) Gonk? Did his daughter keep the kid?? He seemed a bit off when i mentioned your name but didnt know why... Why you gonna fit 2 cats?
Discussion Starter #18
yeah me and his daughter have a little un Sophie she's coming up 4 now
ask him how Sophie is for me willya
Dont you see her mate? I wont see him until wed next week.. Its the way the shift works. Sorry man..
1 - 20 of 28 Posts
