1 - 9 of 9 Posts
has this ever been done???/
and if so does anyone know where i can get an inlet manifold for webers?
you will need to get a mappable ecu for the ignition as you cant use a dizzy. maybe an emerald or something.
inlet manifold would be the same as for jenvey 45mm throttle bodies, which i believe are available for the ecotec.
SBD do the manifold aswell.
You could just place resitors across the injector plugs, AFM nd put on the TPS to the carbs and use the std management to do the ign side of things, big of a bidge, but should work.
fone stuart at robinsons, good guy and sorted out my manifold
1 - 9 of 9 Posts
