1 - 14 of 14 Posts
Moderator
What would be the point if your not using uprated fpr, or larger cc injectors?
no its just theres no beifit on a standard engine unless your intending to upgrade at a later date/or its cheaper than a new standard one
If your just changing it because you can theres no need
Moderator
For the full benefit, i'd suggest you use an uprated fpr, but only if your using phase 2 or more.
just got a walbro cos my pump was knackered and the walbro was about a tenner more than a standard one. it'll set you in good stead when you upgrade other parts - don't listen to the mig miserable buggers.
the fuel pump doesnt know whats causing a restriction to flow. it could be someone squeezing the end of the fuel hose for all it knows. it will be fine.
gazturbo said:
anyone else
ok don't use it the enhanced flow will overload your flux capacitor.
1 - 14 of 14 Posts
