right im putting cams in my x14xe engine this wk,do u reckon i notice n e thing?n a mate told me i need a remap or the car will run lean n mess up is this true or not?
well on the x14xe theres precious little room to fit wild cams (without a piston & rod change) so i suspect they are quite mild and hence the standard ecu will cope...a quick fuel pressure setup on the rollers would see it right
