141 - 153 of 153 Posts
Discussion Starter #141
(+ not had much spare time to do anything)
I can relate to that.
Yeah the car is not quite such a bone cruncher now lmao , but you know me I can't help playing with it :eek: so instead of just getting it remapped for the latest setup (again :rolleyes:). I've decided to go down the stand alone engine management road so I can map it myself = :D + Boom = :doh: + rebuild (probably)
Discussion Starter #143
Hi Heds, Sorry about the PM box my mebership has expired since the last time it was used and you get more storage when your a member. I've emptied some of the message out now :eek: .
In theory all 24V senators should have an LSD. However in practice only around half the 24v senators left have still got LSD diff's in them. The problem aroused as the car's started to get older and slip into their 3'rd or 4th owners. Due to the cost of replacing the LSD diff's if they failed and as second hand "open" diff's from "every day" senators were abundant and a lot cheaper people tended to replace the LSD diff' with an open diff'. Hence the only way to tell for sure if your donor senator has got an LSD is to either take the end plate off of the diff, or jack the rear end of the car up and try it.
since your u had know middle box did u have to cut out the floor i have a 8v and got crashed 4x4 and want to put it in it so could i get away with it
That intercooler looks superb and mounted very neatly, top marks for the quality of workmanship! well done, nice project and worth while doing it!
hi sorry to dig this post back up
I am about to do a 4wd convetion on my 2wd calibra is there any other threads on this topic
Hey what happend with all the pictures from this thread i really need them i already got a donor car and dont know where to start cand someone repost them?
Administrator
Sadly due to photobucket changing their hosting. Most photos dont work, butr this is a bit different as even the codes dont show. So i hve no chance of getting the photos to work.
