C20xe standard rev limit
1 reading
10K views 13 replies 10 participants last post by  Gordo
#1 ·
Hi all this is my first post and i am new to the red top stuff as this is the first i have had i was wondering as i just bought a corsa 1.6 sport with a cav gsi 2000 c20xe distributor engine in it when driving it pulls very well got lots of paper work for engine work i.e new head fitted and skimed full engine gasket set bolts and some sensors work only done a month ago. i have found the engine seems to rev way past 7 grand and no limit i was wary of keeping the loud peddal down incase it pops also due to recent engine work is there any way of checking the limiter as i thought it would be about 6500 to 7000 rpm any ideas would be great cheers.
#6 ·
Hi i do have a engine speed tach gun i still have to check this any one know what the ecu uses to sense the speed i.e crank sensor or distributor as this might point me in the right direction cheers
#9 ·
Red line on mine is 7k - whilst I don't know how accurate (?) that is, the limiter cuts in exactly on the line.
Before you go too far, I'd recommend using no more that 7k until you can check the accuraccy of the tacho' (any instrument specialist will be able to check and, if required, recalibrate it for you AND you know exactly what the internal spec of the engine is.
Then you'll have an idea of what the engine can actually be turned to with a good expectation of reliability.
#13 ·
hi thanks for all you replys i am happy changing up at 6500 all day long i was just trying to see what the limiter would cut in at just incase as a few friends dive it on track days and i would not like them to be overreving it does the css control the limiter
#14 ·
Regarding these comments
"if it doesnt make anymore power after 6.5k then like you've said, theres no need to rev the arse off it and potential wear components out quicker."
and
"second that^^^ you lose power after 6250-6500, so acutally your just wearing down components for no reason. hence limiting the engine life.
unless you have your car chipped, raising the rev there is no point bouncing your rev pointer"
Seems you don't understand why a shift point will ALWAYS be above peak power unless that corresponds to maximum rpm for the engine which would suggest the customer or builder cocked up the specification.
The shift point should be where the power/torque at the wheels in any gear drops to the same power in the next, higher, gear - what you are looking for is the maximum AVERAGE power. Where the shift point is for any engine/transmission combination will vary - usually even between the different gears.
However, as most engines, especially those not using racing boxes, run out of rpm before the above point is reached, changing at the red line is normally the best option.
