Hello
I gently need some suggestion to reach 240/250bhp
Actual setup:
Standard coscast head
278 / 11.5mm kent cams + kent springs
Accralite hicomp pistons
Standard conods
Bigbore Martelius exhaust manifold
Complete exhaust line 63.5 to 60mm
200 cells cat
I'm now fitting 45mm t. bodies and ecumaster classic
I was thinking:
Worked / gasflowed head
More aggressive cams but what?
Bigger valves? Yes or not?
Other?
To complete the job
H steel conrods
Solid lifters
Other?
And just for acceleration
Early type crankshaft
(light flywheels and pulley are present)
Bigger valves will help a bit. You are going to need to rev the life out of that for the power you are chasing, so I would make sure everything is well dynamically balanced once you have all the parts sorted.
