when fitting the c20xe into the corsa b, does the rear gearbox mount need spacers set in between the mount and the gearbox to space the engine over towards the passenger side of the car??
does the tie bars need lowered and if so by how much??
any other info about this would b helpfull, thanks
i put a spacer in, think its 10 or 12mm and the gearbox is touching the tie bar now... with plenty of room at the drivers side of the engine!
MigWeb Member
feck me is the search not working AGAIN!!
1000s of conversions completed 100s covered and yet you couldn't find a single one before asking?
For the records, he gearbox does not need a spacer if you dont want to. you can simply run it without with no problems!
which is how i've run mine for the past 3 years
