Iam building a c20ne turbo and read about using a c20let steel head gasket but not 100 percent they fit. Anyone know if they do? Does a c20ne steel head gasket exist? Thanks in advance.
ive heard of people using the older type 2.0 16v heads on the 2.0 8v blocks, and vice versa, so it should fit.
double check all the coolant and oil way passages, match up, before you bolt it together.
from memory, on previous threads in the past, most people say 180 brake is good for standard internals. the 8v (closed deck) block is strong, and will take more, but you might bend a rod or something, if you throw too much boost at standard internals.
