Hi does someone please have a pic of where the throttle cable meets the linkage under the "turbo" black inlet cover?
Basically my throttle cable aint pulling the throttle open progressively or fully :mad: Need it sorting.
had same problem with mine,on mine the clip on the cable was just poorly adjusted,i adjusted the clip to take the slack outta the cable and it was sorted.
Cheers mate
So the end of the cable has a bit that sits behind the clip right? Then that clicks into the linkage???
How should the whole thing sit? How is it adjusted?
The only adjustment is on the outer cable via the circlip that holds it into the bracket before going into the throttle segment.
