Hi there, I have fault code 41 apperaing (first gear ident switch). However, I can disconnect the battery,a nd the fault will dissapear fior about the first 30 miles then it will just spring back on.
any ideas??
the fault is: c20let versions, first gear ident switch low voltage. does that mean the switch is knackered or the wiring????
Rich
any ideas??
Rich
