21 - 40 of 42 Posts
Discussion Starter #26
so what is left:
All parts located in Latvia, but can be easy shipped to UK to friend in london.
so feel free with questions here or pm or can show them on skype talk ;)
1. c20xe Completely renovated bottom (cleaned + painted + re drilled + embedded below the piston cooling)
150 pounds
2. c20xe head with the repaired middle passage ( enclosed aluminum ) + bigger intake channels slightly + Remove the valve and springs, but it all comes down to the set .
150 pounds
3. corsa b 1.6 16v radiator
30 pounds
5. c20xe ground glass for first service size
100 pounds
6. c20xe used
30 pounds
7. c20xe engine parts used : throttle control , fuel rod with sprayers + cams , plates , oil transition
ask part and i will tell you price
9. intake , together with holder which can be welded to the intake manifold
30 pounds
10. Glyco main bearings
30 pounds
11. Glyco crank bearings
30 pouns
13. z20let fuel rail 470cc
150 pounds
14. arp bolts for c20xe, c20let head
130 pounds
15. arp crank bolts c20xe, c20let
55 pounds
16. c20xe c20let
100 pounds never used
17. c20xe c20let new
25 big one 15 small one
23. quaife for f16/f18/f20 or f28 gearbox
650 pounds
21 - 40 of 42 Posts
