1 - 20 of 42 Posts
c20let pistons rod, can deliver to London airport personally
All parts located in Latvia, but can be easy shipped to UK to friend in london.
so feel free with questions here or pm or can show them on skype talk ;)
0. F28 gearbox in very good shape
650 pounds
1. c20xe Completely renovated bottom (cleaned + painted + re drilled + embedded below the piston cooling)
150 pounds
2. c20xe head with the repaired middle passage ( enclosed aluminum ) + bigger valve channels slightly + Remove the valve
and springs, but it all comes down to the set .
150 pounds
3. corsa b 1.6 16v radiator
30 pounds
4. 3.3kw garage heater
20 pounds
5. c20xe ground glass for first service size
100 pounds
6. c20xe used
30 pounds
7. c20xe engine parts used : throttle control , fuel rod with sprayers + cams , plates , oil transition
ask part and i will tell you price
New parts:
8. noname inter cooler
50 pounds
9. intake , together with holder which can be welded to the intake manifold
30 pounds
10. Glyco main bearings
30 pounds
11. Glyco crank bearings
30 pouns
12. c20let head gasket 1.9 5 layer
80 pounds
13. z20let fuel rail 470cc
150 pounds
14. arp bolts for c20xe, c20let head
130 pounds
15. arp crank bolts c20xe, c20let
55 pounds
16. c20xe c20let
100 pounds
17. c20xe c20let new
25 big one 15 small one
18. c20let pistons Mahle
400 pounds
19. cooling radiator ventilators
35 pounds
20. JOM tachometers with shift light
30 pounds
21. KENT CAMS stronger valve springs
50 pounds
22. c20let chris astley motosports rods
260 pounds
23. quaife for f16/f18/f20 or f28 gearbox
650 pounds
24. z20let oil pump
100 pounds
if some one is scare to buy parts form guy how is in different country, that if i manage to get 3-4 pcs people to buy, i can fly whit them to UK and give them to you personally ;)
Cranks are sold, rest is still for grab ;)
if you have your option on price give me note ;)
How much for the four C20XE injectors posted? I don't need the fuel rail and not sending it will save postage.
Your mailbox is full so is rejecting messages!
Does the XE block come with the caps in the correct place and bolted down?
1 - 20 of 42 Posts
