the broken wire which has been rubbing, Can i not just repair (replace) this to stop the light flashing
He's talking about 4x4 by the way.
Yes have a look to see if it is broken.
Locate the accumulator. That's the black bulb on the passenger side. Well behind all the stuff at the top it a pressure switch pointing to the back of the car. It should have 2 brown wires on it. One brown/green.
Locate the see if the wires are ok.
You will still need to make sure that the ecu is happy with the tx box temp.
