Ok no problem, I've got all night. Prices are posted and negotiable.
Inlet manifold and plenum £25
Exhaust downpipe which is in good condition £17
Cylinder head (will not post due to geometry and weight ) £30
Usual various sensors- please ask as there's quite a few.
Full block with crank, sump, pistons, rods, and pulleys £40 - collected only.
Please note this engine was removed without me actually running it so if there's anything anybody needs please let me know and I'll take it off and check it and if it's no good or damaged I'll let you know before requesting any dollar.
I can bring parts to you if your not too far away for cost of petrol as delivery.
ive stripped the engine tonight and it was a snapped timing belt. it has also bent 2 inlet valves from what i could see, apart from that everything looked ok.
the piston heads looked ok and there wasnt any sign of the valves hitting the pistons.
the head gasket looked liked it was replaced recently so id confidently say the head or block are ok
