Hi,
Ive got an astra 1.7TD isuzu engine and Ive noticed recently that its leaving
oil patches on the road so I looked at the engine after running it abit and I can see oil dripping down the left side of the engine, I think somewhere between the engine and Cambelt black plastic cover. I put some paper under the car and left overnight, it seems that the leak either stopped or dropped very little oil as I saw about 5ml of oil on the paper.
Does anyone have an ideas on what could be causing this leak? and if its an expensive job? :confused:
Mac :beer:
Maccay said:
Any TD owners here?
Yea, but it dont leak oil, except if you use the copper sump plug washer ( hemp string sorts that out )
Havnt a clue whats up with yours.
Are all the sump pan bolts done up proper
i'd say its a seal, chances are if it is 'should' be cheap... it will be agro to do as the belts will have to come off, so u have to lock up the timing to do it. not easy, but probly cheap.
