1 - 11 of 11 Posts
What drive shafts and mounts should i use on a big block corsa conversion. IIRC Astra shafts are the same size as corsa ones... does this meen that i use Astra shafts with corsa outers? What about engine mounts? do the engine mounting points on the chassis differ with different engines on a corsa?
James
hmmm i'm sure some ppl were saying they are the same length?....
could be wrong tho
NotNormal said they were the same length ages ago, but it doesn't ring right. The track of the corsas and astras is different is it not?
Maybe with CV joints on, they can appear the same length...
well if corsa was same track as astra..... why would the nova wide track kit come with tca extensions when u could just use a pas/non pas corsa rack :rolleyes:
and the nova is 100mm thinner than an astra.... but if fitting the corsa pas rack on a nova you take 24mm? off each side :rolleyes:
right, so back to the origonal question... what shafts do i need to make up shafts that will fit?
1 - 11 of 11 Posts
