1 - 7 of 7 Posts
Av got a pipercross viper induction kit on mine but I got told they need to be set up on a rolling road to run right. alot of the C20XE run like a pile of horse poo with filters on your normally better going for a panel filter
Panel filter + Drilled airbox will be best bet. Also run a cold air feed aswell.
Other than that, anything sealed, Viper, Apollo or BMC.
You want to search for best filtration tests, if you value your engine that is...
Iv heard good things about apexi personally
Id go with Green as well. Affordable, high quality and last a long time. K&N's turn pink after a while, even after re-oilling them. Apexi are quite good, I hear alot of rumbles from the states about their filters but to be honest, I dont think there is going to be a huge performance or quality difference in them to warrant the increased cost over a green kit.
1 - 7 of 7 Posts
