Just re-painted a bonnet, tailgate and bumpers using my spray gun (first time using it). Finiah is somewhat dull and orange peely/rough. Should I get some G3 stuff or will normal rubbing compound be sufficient to smooth it down. There's so many items to choose from, just wanted some input on what you lot have used and found works best. I noticed in the paint shop that are several "G" products (G3, G4, G6, G7 etc) which would be best suited for use with cellulose paint?
Andy
P.S. Paint is metallic black and had been lacquered also
depends on how bad the finish is on the lacqure from the sounds of it id go over it with g3 then either use g10 then to finish with a good polish u may find that using g3 then polish is good enough
