1 - 8 of 8 Posts
At the moment my car is off the road due to lack of insurance. For some unknown reason, over a period of about 2 weeks the battery is draining itself and goes flat.
I have tried different batteries and one of the batteries i have tried i know is ok.
The only thing i have in the car which is not there as standard is:
Thatcham Immobiliser,
Alarm and immobiliser,
Pioneer Head unit and pair of 6*9's, and a pair of 8" co ax speakers.
I start the car every few days and drive it about 500 yds just to keep the cobwebs away, and i leave it idle for about 10 minutes after just to make sure the battery gets a quick charge.
Please help its driving me mad.
thanks in advance
Matt
I had the same sort of problem battery going flat all the time and with the help of a meter to check the battery drain I found it was my boot light playing up that was doing it. good way to check pull out a fuse check the drain and so on till you find the one.
hope this helps.
never thought of doing that. Thanks will get a meter and try and see whats up. Never thought about the bulbs either.
Funny how sometimes little things solve irritating problems.
Cheers GLSi
Not driving the car very much at all really at the moment, just 500 yds every few days to keep it happy.
Could that still be the alternator. Oh actually, i have just remembered, on the lcd dash the battery indicator shows about 13.5 - 14v so i guess it is charging the battery ok. What else could it be apart from maybe electrics or a bulb playing up somewhere?
Yeah, that`s all very well having the voltage there but what about the current???
Bear with me a mo, a car battery, 12v yeah?? and what about one of those lighter/keyfob remote batteries, 12v yeah?? but why won`t the keyfob battery start ya car ...... no current that`s why!!
So OK you`re getting 13-14v but if you`ve got a bit of 5h1t on one of the connections somewhere between the alternator and the battery you may well get the voltage you`re looking for but no `Oomph` behind it (so to speak) so I woul reccomend before you go replacing batteries and alternators willy-nilly remove, clean and apply some copper grease to ALL connections between the battery and alternator and see how you go from there :D :D
had same prob found it was the boot light switch (the bracket was bent and therefore didn't switch off), another problem I had was **** connections on the alternator (but I suppose if your car has been off the road then this wouldn't realy apply of your motor).
1 - 8 of 8 Posts
