1 - 7 of 7 Posts
ok you know my project and p8pro dta, what do i need just to make it run , you know no boost or good fuel consumption etc no water / air compensation maps etc just so i can drive it to the mappers and make sure it fires/runs before the super size bill comes along saying that the coil was wired wrong and the crank sensor etc that will be hundred's of thousands of pounds plz Mr plus mapping plus VAT and a tank of fuel and a trailer to get it there if it don't run
lmao :D :eek: :mad: :beer: :p
im sure it will run on a xe map ?
It will run on an XE map and should drive to the RR ok. Just don't risk high revs or load untill it's been looked at.
dta base map is sufficient to start it and check it over. run no boost if you must drive it to the mappers else call green flag lmao
Broos3 said:
lol simply removing the boost pipes would be a better idea no?
best you can do really is wedge the waste gate open and don't push it, in my case its worse cus its a GT turbo which means it spins even easier than a normal turbo, plus you would need to blank boost pipes and fit another air filter for the open inlet pipe to the plenum :p
and this air filter ain't fitting no where but the front wheel arch / wing lmao
1 - 7 of 7 Posts
