Here is a full Koni suspension kit removed from a Astra Mk3 GSi Turbo.
The kit was bought late 2007 and fitted to the astra and used for aprox 1 yeah and no more than 10k miles.
The car was off the road for aprox a year while engine was being rebuilt only to decide to break the car in mid 2009.
Full Koni adjustable suspension kit.
Includes
Front top adjustable yellow shocks
Rear top adjustable yellow shocks
Set of 4 -40mm springs.
koni adjuster knob
this is the full koni kit for the Astra Mk3 GSi at the moment cost in the region of £400+
All shocks are in perfect working order. They were tested before being removed and each shock felt perfect and the adjuster on each shock works perfectly making each shock go from pretty soft to stupid hard :)
As the car was sat up for aprox 1year (unfortunatly in the sticks) the rear shocks has some surface rust coming through on the upper sections (only like a dust cover) , bottom shock body itself is pretty mint
All springs are very very good you can see they havent had too much use. Very little corrosion on the springs. only where the couple coils touch each other but very good.
Many years of life left in these.
I can include the front legs if you want (with 4stud hubs/top mounts, needs clean/paint) but u will have to cover the extra on postage due to weight (Extra £12)
otherwise its 4x shocks and 4x springs and adjuster knob.
Im looking at £175 for the whole kit, much cheaper than the £400+ new.
Postage £12 for shocks/springs or £24 for the fronts complete/built up
Heres some quick pics. ill grab pics of the rears shortly wont be long just gotto dig them out of the box.
Need the funds so open to reasonable offers :)
Includes
koni adjuster knob
Hi, are these still available. If so contact me on 07754439138
